Thotel position sensor 1 low power and whent I thoch the brake pedale the gaz pédale
J'ai un Avéo 2010 et un probleme avec la pédale de gaz (position sensor 1 low current)
J'utilise un scanneur innova 3030g2 pour le diagnostique.
Quand j’appuie sur la pédale du frein la pédale de gaz arrête de fonctionner.
Throttle position sensor is a variable resistor. If you have an ohm meter, connect it on both electrical ends of the sensor, rotate the shaft 1/4, 1/2, 3/4, and full. The resistance should be linear with the shaft position, if not replace it. I'm not aware of the brake pedal, and throttle having any relationship, also check under the dash for any loose wires. Sorry I don't Francias.
