01 Chevy 2500 HD Random misfire
I have a 01 Chevy 2500 HD its been sitting for 2 years so i pulled it out of the weeds and done a few things and i need a little help trying to diagnose a problem.
its throwing a random misfire P0300 i believe,,,,,, with a service engine soon light FLASHING. replaced.. transmission oil oil filter fuel filter air filter plugs wires coil packs cleaned the mass air flow sensor also ran sea foam and 2 tanks of fuel through it however i have a "service engine soon" light that only goes off SOMETIMES!! when cruising about 50-55mph OR!!! slowing down to a light or stop sign. Any advice will be greatly appriciated and followed up on. |
I'd suggest go back through check everything, i.e. plug wires on tight. You have a general misfire according to your post, might be worth pulling the fuel tank, and possibbly replacing the fuel pump. At least check for anything that could be obstructing the pump
thanks yeah i figured that would be my next step.
