Chevrolet Avalanche
Platform: GMT 805 & 900
'07 Avalanche blowin' a P0521 code-HELP!
Old March 1st, 2010, 9:52 PM
indyrob's Avatar
Exclamation '07 Avalanche blowin' a P0521 code-HELP!
Have a '07 5.3 Avalanche blowin' a P0521 code. Engine smooth, no leak detected. Also tire code when times are fine. Bad sensor/pump? I'm thinking sensor. Help needed! thanks!
KGWolfAngelTX (April 12th, 2024)
Old March 1st, 2010, 10:10 PM
suzuki-guy's Avatar
I would take it to the dealer either the oil sensor is bad or oil pressure is abnormally low. Isnt it still under warranty?
Old October 19th, 2013, 4:25 PM
dwkent's Avatar
Same problem, used 3 qts between oil change. Changed switch 3 months ago and complained about oil consumption. Poor GM response, this time I didn't add oil between changes. Got GM attention this time. They flushed the engine and my oil pressure is 170 kPa or 24.5 lbs. GM is going to pull oil pan and check cam shaft and oil pump. Will keep the result posted.
Old October 19th, 2013, 7:44 PM
Welcome to the forum ..
Do keep us posted , you may also want to update the Avalanche portion of the forum so others may learn from your experience...
Avalanche - Chevrolet Forum - Chevy Enthusiasts Forums
Old April 12th, 2024, 2:38 PM
KGWolfAngelTX's Avatar
Similar issue. We have an '09 Avalanche with a 5.3L J-type (LY5) -- had this same type motor in an '07 Silverado which had the Oil Pressure sensor issue and Chevy didn't have a resolution for it back then (2012-2015). Bought this truck with 172K miles back in 01/2016, she now has almost 286K (114K in 8 years). Had the Oil Pressure sensor replaced 2/15 of this year, then had the Oil Pump replaced 3/21 of this year, been driving it since and then last night the low oil pressure issue started up again, so this morning the mechanic replaced the Oil Pressure sensor (2nd time this year) thinking it might have been a bad sensor. After letting it get to temp at the house, and the mechanic giving thumbs up, hubs drove it 26+ miles when it started throwing P0521 again. Oil levels have been perfect the entire time, we use Fram's XG10060 with Quaker State Full Synthetic 5W-30, level checks a couple times a week, and oil changes every 5K. She's solid and runs quiet (cant tell it's idling), this is the only issue that we are aware of and about to have hubs put a manual oil pressure gauge in her, as I don't trust this computer stuff. This is driving me insane, so can anyone explain or have any suggestions? No sarcasm or disrespect please. Help?!
Stormy, our 2009 Avalanche
Mota1983
November 17th, 2012 2:03 PM
kasandera
March 26th, 2012 7:32 PM
Clark317
February 8th, 2012 11:03 PM
Bocephus
December 15th, 2008 11:15 PM
robbiestuff
June 22nd, 2007 10:25 AM
Quick Reply: '07 Avalanche blowin' a P0521 code-HELP!
