08 silverado 1500 5.3 Lifter/Push rod issue?
Ive got an 08 Chevy Silverado 1500 LTZ with a 5.3. I was driving on the highway when I had a lifter collapse. Started running rough due to a misfire. Limped her home and determined it was a lifter due to the ticking sound and the misfire. I started digging into the motor. After removing the heads and valve cover. I pulled the lifters and sure enough the AFM lifter on cylinder 6 had collapsed on me. I replaced all the lifters on the passenger side since i had everything pulled already. When I got it all back together I still had a misfire. I changed the fuel injector, coil, plug and wire to help eliminate possible issues. Nothing fixed the misfire on cyl 6. I then took off the valve cover to see the rocker arm wasnt moving. I took it off to inspect the parts and saw nothing. Arm looks pretty good and the push rod doesnt seem bent at all. I put it back together and it ran great. Proceeded to drive for the day and ran perfectly. The next day I make it a mile down the road and the misfire started again. Took the cover off again and the same thing. I believe its the rocker arm for the intake thats not moving (3rd rocker arm from the rear of the engine). I took them off and reinstalled them again. Same situation. Ran great for a day then next day drove it for a mile and misfire again. I will say that the last time I took the rocker arm and push rod off. I had someone turning the engine by hand while I put a little pressure on the rod. There seems to be a sweet spot to where the rod wants to move and where it doesnt. Maybe after driving for a while the rod shifts somehow? This shouldnt be possible though should it? Its suppose to sit on the top of the lifter and I torgued all arms to 22 ft lbs. Any ideas? A few notes: I looked at the cam lobes and didnt see any scaring or pitting, All torque specs were followed. I am no mechanic but I feel like I knew enough to tackle this issue.
Originally Posted by Joem90
(Post 510587)
Did you replace the Valve Lifter Oil Manifold (VLOM)? That should be replaced any time an AFM system is taken apart |
I did not. Ill be digging into it again here soon and Ill make sure I replace that as well.
| All times are GMT -5. The time now is 4:03 AM. |
