2006 malibu ls airbag system
I have a malibu 2006. It was in a minor crash but airbags deployed. And i know how to fix it but. I was wondering do the impact sensors. Need to be replaced. They are not damaged. And if so. How do i remove them. It seems they are not removable.
<dt><a id="d362e74">Accident With Frontal Air Bag Deployment — Component Replacement and Inspections</dt> <dd> After a collision involving air bag deployment, replace the following components:
crash sensor replacement
I believe they have a internal torx head on the end of the cap screw. the head the cap screw clamps the sensor to the crossmember. loosen the capscrew and slide it off. the trick is know if its left or right hand thread....because your working from the foot of the screw not the head. I have seen some right hand and some left hand thread.
I dont think it has side restraints i already removed the seat belts. the airbag module from what i read. Is under the middle console. Is this correct ?
Thanks for the info.
Ok. Im not sure how to get the screws out on the front restraint sensors i dont want to strip them. There is no way to acces the head of the screw is there a special kind of tool?
um, maybe re-read my last post.
Do a google search for images of external torx sockets. Next look at the exposed end of the screw that holds the sensor. I'm betting it will all come together. |
I figured it out. Pretty simple. I didnt know those sensors slid over after they are loosened.
