-   General Tech (https://chevroletforum.com/forum/general-tech-10/)
-   -   96 corsica error code PO441 (https://chevroletforum.com/forum/general-tech-10/96-corsica-error-code-po441-16554/)
pionex292 Jun 15, 2008 7:43 PM
still getting service engine soon light on my 96 corsica listed below is every thing i have done so far and not fixed yet
Ihave a 1996 corsica 103,000 mile
Error code problemPO441 no purge flow
Smoked all vacuum lines checked found no leaks
replaced gas cap
Replaced purge solenoid
Cleanedand resealed vacuum line that attaches to intake next to pvc valve
replaced charcoal canister.
still getting error code po441 no purge flow
need help to fix this [/align]
shawnvw Jun 15, 2008 9:40 PM
RE: 96 corsica error code PO441
Have you checked for ign voltage on the pink wire at the purge solenoid?
pionex292 Jun 19, 2008 2:24 AM
hi not yet i told my mech about your reply be he is thinking its the fuel sylinoid in gas tank
but to me vacuum purge would not have any thing to do with fuel tank only thing i found we have not tried yet is
check pink wire to purge valve
replace vacuume switch
or aproblem with the PCM board
what might you think?
shawnvw Jun 19, 2008 4:19 PM
There is a pressure valve in the gas tank that could fail, and cause the system to not hold a vacuum, which in turn could cause that code to set
There are many things that could contribute to the code being set from a crack\broken hose, bad purge solenoid, bad vacuum switch, or the pressure valve in the tank
pionex292 Apr 11, 2015 6:06 PM
I think we got it fixed I was wrong I had not bought a charcoal canister we replaced it last week found 2 lines mild splits and finally replaced this GM OEM Efe System-Switch 24506192
which I think was main problem in 2008 1 day so far no light on dash im hoping in 2 more days of driving the light stays off make sure if you have a purge vacuum leak replace this switch on back of motor GM OEM Efe System-Switch 24506192 thanks for all your help
