lambert44 |
June 24th, 2012 10:23 PM |
98 silverado 1500 electrical issue
Ok so my truck is running fine all day ran some errands, **** it off for no more then two minutes, went to fire it up and nothing.. i mean nothing no clicks no radio, no lights, no guege movement nothin. So obviously first is check main fuses, nothin all good, check door fuses, same thing. So i checked the battery thinkin magically it went dead, battery was fine. My brother shows up says gm had problems with the ignition switch in the column on these pickups, i figure ok before i start rippin the colum apart to change the switch ill check under the dash for cut or burnt wires or somethin shortin out. What i found was surprising, and how i didnt notice this before is beyond me.. what i found a spider web non factor lookin mess, relays wires soldered together and a couple brain box lookin things, now it looks half wey professional like someone knew what they were doin but one bos says "gm passlock bypass module" and some of the wires from the ignition switch are spidered into this box and the others, could this be causing my problem, or is it the ignition switch. Ive never seen anything like this. Thanks
