AC Problems
First off, my apologies if I am posting in the wrong section. I’m new to the forum so hold on tight. I have a 2005 Chevy 2500 6.6L. Last year the AC worked but would freeze up and stop blowing, then eventually thaw out and work again. This year it doesn’t work at all. I put a test light on the compressor plugs and had no power to the compressor. I don’t know whether or not to replace it or if it’s an electrical issue somewhere. All the fuses are good. Any thoughts would be appreciated! |
if the system has low pressure...the low pressure switch will open and not allow the compressor to turn on
you could briefly (to long and the compressor will be damaged) jumper the low pressure switch...if it engages the compressor...have the system recovered, charged and leak tested. how were you able to confirm the evaporator froze up? |
Originally Posted by tech2
(Post 357029)
That is indicative of low freon charge, and since it is a closed system, you have a leak.
Originally Posted by kevinkpk
(Post 357076)
Originally Posted by okstate31
(Post 357079)
Ok, Iv tried putting Freon in it but it says it’s full. Should I just go ahead and drain the system? Do would I go about finding the leak? |
(Post 357082)
Ok, what say's it's full? If the system is full, freon isn't the problem.
(Post 357084)
Just hooking the hoses up, gauge says it’s full. Is it normal to not have power to the compressor? Like I said earlier, I took the plugs out and put a test light on them and there was nothing |
