-   General Tech (https://chevroletforum.com/forum/general-tech-10/)
-   -   bad pump or worn bearings (https://chevroletforum.com/forum/general-tech-10/bad-pump-worn-bearings-62248/)
trav502 Dec 11, 2013 10:17 PM
just bought a used/rebuilt engine for my truck. Bottom end is used unsure of miles. the oil pump is supposed to be new, when i start the truck it carries 50psi then gradually falls off to 5-7 psi when it comes up to temp. oil is new 10w-40 pennzoil, with a Bosch filter. Im going to change the pump. So should i change the bearings while im in their and also should i put a high volume pump in. The engine is built some and will be ran hard, just trying to get someone else's opinion
