Bypass the ignition system
I just finished rebuilding an older column for my 1974 chevy malibu. Got it all in and wired but it won't start. I have to move the car very soon, so I was going to try and bypass the ignition switch.
There are two switches on the steering column, I think the ignition switch is the one closest to the steering wheel where the steering column linkage fits into. I pull the wires back off the column and was trying to use a momentary switch to get the car running. Nothing happened, I think I may be using the wrong wires? Does anyone know how to get this car to start and drive using the steering column wires. I just got the car from my brother who died and have not yet ordered a service manual. The column was broke so I took it out and did the best I could rebuilding it. Also having a slight issue with getting the lower shaft to fit the part that goes from the gear box up. Any suggestions on this issue? Appreciate any help I can get. |
Welcome from Florida. Make sure the neutral safety switch is working and wired properly. If the harness is in bad shape you might have to get another one from a vintage car junk yard. There are several of them if you do a search on Google. You might be able to make a harness yourself if you can get hold of a schematic.
Originally Posted by oldchevy
(Post 473654)
| All times are GMT -5. The time now is 6:03 AM. |
