C2500
Hello all I have a 98 c2500 with 5.7 vortec that has me scratching my head.I’ve replaced the following:injectors,plugs,wires,distributor cap,egr valve, fuel pump,ignition control module,fuel filter. I’m still having a skip in it and if you give it throttle while taking off it almost cuts off. It’s not throwing any codes that’s why I can’t figure out what’s wrong any help or advice would be appreciated!! |
Originally Posted by Crazeerebel
(Post 402511)
c2500
(Post 406117)
Did you clean the MAF sensor yet? Sometimes they need cleaning/replacement but wont throw a code.
(Post 409483)
Thought that might be the problem seen couple videos said to unplug MAF sensor with engine running if continued to run that was the issue I unplugged mine and it continued to run so gonna try cleaning or replacing it will update |
