Can I put slightly larger diameter tire?
Hello,
My car originally needs 225/70R16. A friend could give me a set of alloy rims with 225/75R16. This is 3.12% diameter increase. I read 'stay within 3%'. Can I take these 225/75R16 or should I avoid them? Main concern - can this much of an increase do any harm to transmission?? I know about the speed / odometer reading, that's not an issue really. The real issue is transmission. Maybe there are other serious concerns in this given case? Please suggest if you are knowledgeable. Thank you. |
it affects many things, not just transmission
abs, traction control, speedo/odo, braking performance, fuel economy, etc. It's a good rule of thumb. Try to stay within the 3% |
| All times are GMT -5. The time now is 5:11 AM. |
