CHEVY 87-95 350 TORQUE SPECS
I AM PLANNING TO PUT A 87-95 350 IN 82 MONTE,AND WAS WONDERING IF ANYONE KNEW THE TORQUE SPECS ON THE ENGINE OR LINKS THAT MIGHT LEAD TO THE INFO.THANKS ALOT GUYS
RE: -
Go to a dealer and ask if you can use thier Alldata system, they will probably let you use it.
RE: -
i assume your talking about engine spec's 88-95 5.7 cylinder head 65 ft lb main bearing bolts ,outerbolts #2,3,4 70 ft lb,all other 80 ft lb's.connecting rod bolts 45 ft lb's.harmonic ballancer 70 ft lb . flywheel 1988-91 60 ft lb 1992-95 70 ft lb.intake manifold 1988-95 35 ft lb. this from chilton's manual #8055 1988-1996 years chevy gmc full size truck manual can get it from o'reileys
