Common tech Abbreviations and Acronyms
Here is a start on untangling these codes. If you run across acronyms or jargon you don't understand, send them in.
AFC - Air Flow Control ALDL - Assembly Line Diagnostic Link. Former name for GM (only) Data Link Connector, the connector socket into which the scan tool plug is inserted; sometimes used to refer to any pre-OBD II computer signals ASE- Automotive Service Excellence. To become fully ASE certified, there are 12 areas of expertise a mechanic is tested on. BCM- Body Control Module (systematic controls lighting(DRL/AHL), climate controls, radio, automatic intermittent wipers, etc) CAN - Controller Area Network CARB - California Air Resources Board CFI - Central Fuel Injection (a.k.a. Throttle Body Fuel Injection TBI) CFI - Continuous Fuel Injection CO - Carbon Monoxide CPS-crank position sensor DLC - Data Link Connector Driving Cycle - A specific sequence of start-up, warm-up and driving tasks that tests all OBD II functions (Details) DTC - Diagnostic Trouble Code ECM - Engine Control Module- usually the main in-car computer controlling emissions and engine operation ECT - Engine Coolant Temperature ECU- Engine Control Unit- same as ECM, but usually called ECU in imports. EEC - Electronic Engine Control EEPROM or E2PROM - Electrically Erasable Programmable Read Only Memory EFI - Electronic Fuel Injection EGR - Exhaust Gas Recirculation EMR - Electronic Module Retard EPA - Environmental Protection Agency. Federal agency. Office of Mobile Sources is the branch concerned with auto emissions. ESC - Electronic Spark Control EST - Electronic Spark Timing DPFE - Differential Pressure Feedback EGR sensor ( On Ford OBDII systems). DTC - Diagnostic Trouble Code FLI - Fuel Level Indicator Fuel Trim - Engine computer function that keeps the air/fuel mixture as close to the ideal 14.7:1 stoichiometric ratio as possible HC - Hydrocarbons HEI - High Energy Ignition HO2S - Heated Oxygen Sensor IAC- Idle Air Control IAT - Intake Air Temperature ICM- Ignition control module ISO 9141 - International Standards Organization OBDII communication mode, used by Chrysler and most foreign cars. One of three hardware layers defined by OBD II J1850PWM - (Pulse Width Modulated) SAE-established OBD II communication standard used by Ford domestic cars and light trucks. One of three hardware layers defined by OBD II J1850VPW - (Variable Pulse Width Modulated) SAE-established OBD II communication standard used by GM cars and light trucks. One of three hardware layers defined by OBD II J1962 - SAE-established standard for the connector plug layout used for all OBD II scan tools J1978 - SAE-established standard for OBD II scan tools J1979 - SAE-established standard for diagnostic test modes J2012 - SAE-established standard accepted by EPA as the standard test report language for emission tests MAF - Mass Air Flow MAP - Manifold Absolute Pressure MAT - Manifold Air Temperature MFG - Manufacturer MIL - Malfunction Indicator Light. The "Check Engine Light" on your dash. NOx - Oxides of Nitrogen O2 - Oxygen OBD - On-Board Diagnostics OBDII or OBD II - Updated On-Board Diagnostics standard effective in cars sold in the US after 1-1-96 Parameters - Readings on scan tools representing functions measured by OBD II and proprietary readings PCM - Powertrain Control Module, the on-board computer that controls engine and drive train PCV - Positive Crankcase Ventilation PID - Parameter ID Proprietary Readings - Parameters shown by on-board computers which are not required by OBD II, but included by manufacturer to assist in trouble-shooting specific vehicles. PTC - Pending Trouble Code RPM - Revolutions Per Minute SAE - Society of Automotive Engineers, professional organization that set the standards that EPA adopted for OBD and OBD II Scan Tool - Computer based read-out equipment to display OBD II parameters SES - Service Engine Soon dash light, now referred to as MIL SFI - Sequential Fuel Injection Stoichiometric ( Stoy'-kee-o-metric) Ratio - Theoretical perfect combustion ratio of 1 part gas to 14.7 parts air TBI - Throttle Body Injection TPI - Tuned Port Injection TPS - Throttle Position Sensor TPMS- Tire Pressure Monitoring System TV- as in Trottle valve VAC - Vacuum VCM - Vehicle Control Module, the in-car computer that oversees engine management, transmission operation, anti-lock brakes, and other functions not directly related to emissions control VIN - Vehicle Identification Number VSS - Vehicle Speed Sensor WMS= wheel mounting surface. WOT - Wide Open Throttle 700R4/4L60- are basically the same thing. 4L60E is an electronically controlled 700R4/4L60. 4x4x4=4wheels x 4driven wheels x 4 doors 4x2x2=4wheels x 2driven wheels x 2 doors 4x2x4 4x4x2 4.3/700R4/207= example of: Engine size/ transmission/ transfer case |
RE: Common tech Abbreviations and Acronyms
MPFI stands for multi port fuel injection
general discussion
Hi,
Well this is very important in student life or in professional life that learn lot of abbreviation for writing short forms for understanding. |
CKP- Crank position sensor
CMP- Cam position sensor EBCM- Electronic brake control module |
Wow,,,,,,,,,, Great collection of Chevrolet Car`s, but if there is pic present with model name then its might me too great for visitor ...
Thank you very much. This is great info for the Abbreviations and Acronyms.
___________________________________________ Arctic Cat Atvs | Chevrolet Trucks For Sale |
I am a mechanical engineering student.Hope that your list will be very helpful to me.
sorry if im doing this wrong but just purchased a 2007 Silv. LTZ. The dealer told me it is normal to hear a ejecting noise or spining noise from the Navigatin DVD if it is in. Could someone please tell me if this is true and if so is there a way to get it to stop..thanks for any help
roblcopeland99, I would like to escalate this question to our Techincal Assistance team. What I need to do is is for you to direct message me your name and VIN. Hopefully I will get an answer back for you.
Jeff Morris, Chevrolet Customer Service |
well this is very important for anyone to know thanks for the info.
| All times are GMT -5. The time now is 4:22 AM. |
