Comparing Tires Calculator
Here is a great calculator that will tell you the difference between your current tire and a new tire (size). It automatically calculates the difference in Sidewall Height, Section Width, Overall Diameter, Circumference and Revs per mile. It also tells you the difference in speed, for example, if your current tire goes 65 MPH, with the new tire your actual speed is 68.56 MPH. (See sample screen shot below.)
http://www.discounttire.com/dtcs/infoTireMath.dos http://i109.photobucket.com/albums/n...atorSample.jpg |
Originally Posted by aja72
(Post 153726)
Shocking, i want to try this calculator. Tell me how can i use this.
Hey i am hearing this for the first time. amazing calculator it looks cool man there is no necessary. for us to maintain all these stats. because calculator well help us.
Fellas, this calculator has been available for quite a while, and linked on this Forum numerous times. However...
I'd suggest that you use your OEM size in the first three cells, it'll give you more accurate info, specially since many are not running the exact OEM. Other than that, just follow the directions. |
shocking and its very interesting and i want to use it.
Cool link!
Originally Posted by dianneazuma54
(Post 233476)
How much leeway is there in tire sizes?
Now, if you're just talking about a slightly larger tire on your existing rims... The rule of thumb is... That you don't go with a Tire that's over 1" wider than your Rim Width. (is that what you meant ?) |
garage door repair springfield
Nice!I like your post and also the color of the car..Nothing to worry about problem it looks like very compatible..
Thank you for sharing here :) |
woow thats amazing link to look up at.. i liked it a lot and would recommend others to use it....
Tire Size Difference Calculator
The only Calculator that I can find on this Site, is one for Offset at... Chevrolet Forum - Chevy Enthusiasts Forums There is however a Difference Calculator which gives you Speedometer error differences at... Tire Dimensions Made Simple - Discount Tire If I have somehow missed this feature on this Site, please post the location. |
| All times are GMT -5. The time now is 4:12 AM. |
