engine removal 89 chevy van
Hello, just throwing a question out there for anyone willing to answer. Pulling the engine out of my 89 van (engine only) and I read somewhere that the 3 torque converter bolts needed to be removed. I'm curious if transmission fluid will leak out all over and if I need to drain the transmission fluid ? Thank you
Last edited by spacialvan; October 3rd, 2011 at 7:02 PM. Reason: figured out my question and wasn't sure if this was the proper place to ask one
the torque convertor would stay in the tranny jut undo the bolts stick a bar between torque and block give it a little push back and pull the engine out you should be ok as long as the torque convertor stays in the bell housing
burgiedanny
November 7th, 2023 9:15 AM
dotdalea1
July 17th, 2013 9:29 PM
ccampbell928
June 3rd, 2013 10:28 PM
offroadinjersey
October 6th, 2009 12:15 PM
