exhaust question 04 silverado
04 silverado 5.3l 4x4 ext cab. Since last fall i've had a tickish type sound (also sounds airy). I checked under my truck while the truck was running and I felt exhaust leaking at the first joint in the exhaust pipe (on drivers side). i did that last fall. Today was fix it day so i pick up a exhaust gasket from lordco. after removing the 3 nuts on the drivers side and then the ones on the passenger side the exhaust system dropped. I was expecting to find a broken gasket on the drivers side but i found nothing no sign of an old gasket. there was a round ring that was recessed into the end of the pipe that i could pop in and out.( so there was no old gasket there). I put in a new and tighten everything back up but the sound was still there and there was still exhaust leaking in the same spot.( its right at the join) should exhaust come from there? what did i do wrong?. I'm going to redo everything tomorrow.... just try again
thanks for any help
thanks,
T
thanks for any help
thanks,
T
lph008
February 22nd, 2014 7:13 PM
Icekid87
September 26th, 2012 8:31 PM
LikeARock88
March 20th, 2010 12:32 PM
hines182
May 13th, 2007 10:47 PM
