aartod |
June 30th, 2009 10:13 PM |
Fuel pump question....
I have a fuel pump issue and I was wondering if anyone has had a problem like this before or knows anything about it. The car has a 86 4.3l tbi v6 and has a in-tank fuel pump. It wasent starting so when I was checking for fuel I disconnected the fuel line at the throttle body and cranked over the car and fuel spurted out for about a second or two then it stopped flowing alltogether... so I tried it again and the same thing happened over and over. So then i checked to see if there was power getting to the fuel pump all the time not just during the intial start-up--- and there was... I unplugged the connector by the tank and put a test light on it and there was constant power while cranking. So if there is power getting there and the pump is not pumping enough then I figure it needs to be replaced... But I have never see this before, I have seen them not work at all, or not enough pressure, but not a big spurt and then nothing- everytime! What do you think?
