| Maydog |
Feb 12, 2026 6:56 AM |
Good morning everyone, I just wanted to give some additional information. Well after trying the following: unplugging instrument cluster, checking for broken pinched wires on steering column, checking for broken/pinched/ frayed wires underneath the truck, after pulling the fuse panel under the hood apart to see if any plugs were burnt, I then begin to check the ground wires. I set up a test light on the ignition fuse that kept popping and wiggled ground wires, when I got to the one that connects to the fire wall and the back side of the motor, the test light started flashing. I then begin play with it more and the test light with out so out thought, but once I looked closer, it was still on but burning very dim. So I moved the strap because it was still tight and I could never get the light to go all the way out no matter where I put it. So I ended up making two additional ground wires but still the light would not go all the way out. At this point I just decided to try to replace the fuse with a new one to see what it does and it crank just fine. I turned off and cran several times. i put everything back together and drove the truck about 14 miles. I switched it off and crank it right back up. So at this point I switch it off and used my key fob to arm the security system/lock doors and went on my way. I came back about three to four hours later only to find that the truck was doing the same thing again, no crank/no start. I did not check the fuses to see if they were blown again as it was late at night. Once again, any help that any of you can offer please help.
