hummer h3 key stuck
i have problems with my hummer h3 06 i cant remove the key from ignition they key is stuck what can i do?
RE: hummer h3 key stuck
I am not sure if it makes a difference but maybe your steering wheel is locked
no its fee the key are in acc i cant move back to position lock
sometimes on the bottom of the steering column there is a hole that u can put a pen or something it and it will hit a ignition cylinder release button u might want to look for that. also try putting the shifter in low gear and slowly put it back into park.
I do realize that theis thread is severely old but what was wrong with your hummer? I am currently having the same issue. Thank you
Originally Posted by Hummerhonduras
(Post 46613)
