ineed help ! P0455
Helo there every body !
i have a Chevy trailblazer 2006 LT, my problem is the check engine caused by P0455 , gas cap not tight triggers check engine ! IF any one has successfully repaired the issue , please show the way ,, Thank you all ,, thanks also to the administrators,,,hope to hear great tips soon ,, take care :) |
uppppp
the evap system must seal itself to perform leak check diagnosis. if the evap vent solenoid does not close, a large leak dtc will set. check for power to the evap vent solenoid. it should have power with the key on. provide a grd for the vent solenoid. it should click when it opens and closes. if it doesn't, the solenoid is bad.
Originally Posted by tech2
(Post 298786)
Upppppppppp
Thanx |
Originally Posted by myn2015
(Post 298832)
Thanx a milliom tech 2! this is very helpful hint ,,, any one else owns a trailblazer 2006 had this problem gas cap not tight P0455 which triggers check engine and has successfully repaired the issue , it seems like this issue is common with this model... loots of cheers again to all of you;)
Upppppp ,,, please help |
