level truck
level truck
My name is Jeff, I have a 2011 chevy 1500 4 door 2 wd with 5.3 . I do not like the way truck is set up with rear end higher than front . I
have found a shock that would raise the front end but would prefer to lower the rear to make level . Any help would be appreciated
theres tons of leveling kits out and raising the front will be easier than lowering the rear. You do also know that there is a reason the rear sits higher right? Unless you don't use it to haul anything its meant to be that way.
