need immediate help!!!
wifes 1997 chevy blazer wont start!!!!at a loss. about to have it towed from house to have it looked at. i have checked fuel filter. took off quick connect and turned on key. heard pump run and saw fuel piss out the filter.
checked battery. is almost new anyway. checked all plug wires for spark. all good. checked actual plug for spark. all good. using bosch platinum. oil good. coolant good.fuel getting to carb. fuses good.coil good. distributer good. had to charge battery so i took out. later in afternoon i rented code check tool from autozone. went to use it and it said no codes all things pass. can only assume i cleared codes from removing battery. think its the MAF but cant test or check. |
