TIGHT SHIFTING
HEY TO EVERYONE.I HAD A PROBLEM A COUPLE OF WEEKS AGO AND YOU GOOD FOLKS GAVE ME SOME HELP AND I APPRECIATE IT.AGAIN I NEED SOME HELP,I HAVE A99 SUBURBAN WITH A 350.THE PROBLEM IS WHEN I TRY TO MOVE THE GEAR SHIFTER FROM PARK TO DRIVE IT IS REAL STIFF. IKNOW YOU HAVE TO PRESS ON THE BRAKE PEDAL TO SHIFT.DO ANYONE HAVE ANY IDEAS?IS IT SOMETHING IN THE STEERING COLUMN OR DOES THE SUBURBAN HAVE A SAFTEY SHIFT SWITCH THAT IS BAD,JUST CURIOUS BEFORE I START TEARING DOWN THE STEERING COLUMN,THANKS FOR ANY IMPUT
RE: TIGHT SHIFTING
Hi
Maybe you had a mechanical problem, but, try first to apply the hand break before go to parking. If the problem persist is possible some internal problem. Andre. |
RE: TIGHT SHIFTING
IT SEEMS TO BE REAL STIFF GOING FROM PARK TO DRIVE AND IT HAS NOTHING TO DO WITH THE LAST TIME IHAD PROBLEMS.THAT WAS A FUEL PUMP THEN,THANKS AGAIN
