Tire size and Computer
When going to a taller tire does it cause problems with the computer?
I know the speedo will be off but how about shift points or anything else? If it does is there an easy fix? This is for a 2006 3500 Express with 6L. Thank You |
RE: Tire size and Computer
Yes when you put taller tires on when it the spedometer gets off so do the shiftpoints you can get about any performance programmer and they can adjust these things.
heres a programmer for your express: http://www.autoanything.com/performa...0A2647550.aspx
ORIGINAL: FLSTFI When going to a taller tire does it cause problems with the computer? I know the speedo will be off but how about shift points or anything else? If it does is there an easy fix? This is for a 2006 3500 Express with 6L. Thank You |
