vaccum advance
when its hooked up to full manifold vaccum my idle goes way up and comes down very slow
Originally Posted by Mike Stansbury
(Post 428000)
(Post 428008)
Need more input here. What year, make model and engine do you have? How many miles on the odo?
whats your timing set at without it hooked up?
Originally Posted by Irish_alley
(Post 428031)
First, I'd set the timing back to 8, is it hard to start?
Originally Posted by kevinkpk
(Post 428055)
(Post 428059)
No starts up right away,but with my cam I need more timing.
(Post 428061)
When I run the car with the advance not hooked up it's fine,throttles nice and it comes right back to idle
a small device that would slow down the drop and rise in vacuum, and was an early smog control device, that is why I ask this question. |
The cam is not standard, or is built to this engine? At what idle rpm do you have X vacuum? What is the vacuum at say 700 rpm? As oilcan has pointed out, yes the older cars (I have a 70 delta 455 with remninants of smog control) that had a tps that also controlled vacuum advance. This was a small ported attachment. My suggestion is for vacuum advance to set the timing without vacuum, and use a vacuum port from the intake manifold, not from carb, shew, long winded.
