vacuum leak?
So today my "double d' idle mixture tool arrived so i was tinkering with my screws this morning. The passenger idle screw was at 3.25 turns out while the driver side was 2.25 turns out so i thought 3.25 was too much so i evened both out to 2.25 which made it idle rough so i turned them both to 3.25 turns out and the idle speeded up and smoothed out..
The idle was @ 800RPM before adjustment and now it is @ 1000RPM which I know is pretty darn high so I go to adjust my curb idle screw and its not even touching the throttle plate which indicates the throttle plate is closed and the engine shouldn't run so I have a leak somewhere...is this correct? And if i am correct ^ would this be a intake gasket leak or vacuum hose leak or what? Bone stock 85 Impala with 83 E4ME quadrajet |
Forgot to say it has the 305 in it and I had a vacuum gauge hooked up and before adjustment it read a bouncy 18-19 inches and after a pretty steady 20 inches
You should be around 19" hg at 700ish rpm. 1000 is too high, set the idle scew down till you get that. This will affect the vacuum. There is a fast idle screw that is probably your issue with trying to set the idle, can you post a pix of that side of the carb?
I will post a few pics in a hour or so when my cam charges, when I loosen the curb idle screw it does not do anything. When I turn it in about 2 full turns the idle starts to rise.
Thanks for your reply I'll post pics soon |
5 Attachment(s)
sorry it took so long i was waiting for the storm to pass..
i just took pics of the sides and the curb idle screw i couldn't get the camera low enough to get a shot of the fast idle cam from the bottom after i took the pics i started her to see if the idle was high, it was pretty low in the beginning but right after i nudged the throttle a bit the rpm went back up to 1000 :( |
I also found a " remanufactured by Holley " sticker on the back of the carb if that means much ...
from the second picture it looks like the fast idle cam is sticking. you can push down on the lever and it should release.
Originally Posted by jwruss
(Post 220079)
Is it possible the fast idle cam itself is "sticky"? The linkage on that side does seem a bit rusty |
(Post 220079)
Originally Posted by clintsy
(Post 219856)
| All times are GMT -5. The time now is 1:12 AM. |
