-   General Tech (https://chevroletforum.com/forum/general-tech-10/)
-   -   vacuum test (https://chevroletforum.com/forum/general-tech-10/vacuum-test-51311/)
clintsy Jun 20, 2012 6:54 PM
vacuum test
Sorry if this is such a noob question..
Where do you connect a handheld vacuum gauge to test the vacuum?
on a 85 Impala with the 305 and quadrajet
kevinkpk Jun 20, 2012 7:13 PM
Valid question. Insert it into the vacuum system anywhere furthest from the carb.
clintsy Jun 20, 2012 8:23 PM
Thanks..no specific spot or anything?
kevinkpk Jun 20, 2012 8:35 PM
What exactly are you looking for?
clintsy Jun 20, 2012 8:52 PM
I'm just trying to test the vacuum to see if I come across any problems and I need to turn the cap until I get the highest reading...since it's my first time ever doing this I didn't know if there was a "best" spot to check for vacuum
SWHouston Jun 21, 2012 1:48 PM
If you have a Vacuum Canister on your brake system, you probably should do an integrity test first, to make sure there are no leaks. And, a lot of people just use the Tach to get the most RPM's from the setting, then readjust the idle speed.
clintsy Jun 21, 2012 5:43 PM
well i did the vacuum test, did everything i could to get the highest reading except the idle mixture screws because i need the double d socket or fitting for it..i also took a video of it on my cell phone if anybody wants to see
vacuum test (phone quality) - YouTube
if you cant watch it, the needle measures 19 to 18 in but occasionally flickers to 17...in the video i also look at the tach and you can see it dipping down to about 5-600 then back up to 8-900. which is when i think the vacuum gauge drops an inch to 17
tell me what you think
any input is GREATLY appreciated
thanks
kevinkpk Jun 21, 2012 6:23 PM
Well, first of all it is a 305. Setting the timming with vacuum is ok, I seem to see around 800 rpm's on the tach, that too is ok. How many miles on the engine?
clintsy Jun 21, 2012 6:32 PM
55k on the dash but I'm not sure if it rolled
clintsy Jun 21, 2012 6:36 PM
And it unfortunately does not have the original carb on it.
The owner before me changed it from #17085*** to #17083204
