-   General Tech (https://chevroletforum.com/forum/general-tech-10/)
-   -   Vibration while driving approx 40 mph (https://chevroletforum.com/forum/general-tech-10/vibration-while-driving-approx-40-mph-4680/)
amos221 Jan 9, 2007 12:58 AM
I have a 2000 Chev 3500 454 cu in Dually. I have a bad vibration that feels like it is coming from the right rear of the truck. I have had all the tires balanced and rotated and still a vibration. I was told that one of the rear wheels was bent so I replaced it with a new one and had that one balanced...still a vibration. The vibration starts around 40 mph and quits around 50mph, but starts back up at 60mph. I have placed the truck on jack stands and placed the truck in gear to check to see if there was a wobble or anything.....nothing but even turning wheels.....please if anyone can help me with any ideas let me know.......
john1967 Jan 11, 2007 11:04 PM
RE: Vibration while driving approx 40 mph
dont know thats crazy i cpuld not see it being much more is it winter a small chunk of ice or snow can through it off balance
engine2 Jan 12, 2007 1:54 AM
I would road force balance the tires again. Or maybe one of the tires is out of round. Good Luck
amos221 Jan 13, 2007 1:07 AM
Thanks John1967 and Engine2 for the posts..I need all the help I can get.....
Amos221
midwest_guy515 Jan 16, 2007 12:14 AM
Are you sure the vibration is in the rear? I had a similiar problem that I noticed as occassional steering wheel shimmy. It was caused by a worn upper ball joint.
Even if the tires are balanced you still might get vibration or shimmy from a tire that has a bad belt. When I was troubleshooting the bad ball joint I had the shop I bought my tires from check for this during a tire rotation.They were actually the ones that told me exactly which ball joint was bad all for no charge.
Another problem could be if you have a 2 piece driveshaft. Awhile back I was reading up on a lot of problems associated with them. Might be worth the research.
amos221 Jan 21, 2007 11:04 PM
Thanks midwest_Guy15,
I will try all ideas....and I will post what happens
Amos221
