Warning/indicator lamp replacement
I need to replace my CEL/SES and seat belt indicator lamps on my 2002 Astro AWD Cargo.
The lamps are LEDs and are soldered onto a PCB (printed circuit board). Has anyone had this issue? I called a speedo reapir shop and it was $120. Too much to solder $2 lamps to a PCB. I'm not a good solderer and I don't know the specs of the lamps. Does anyone know the specs of the lamps...watts, volts, brightness? |
| All times are GMT -5. The time now is 9:16 AM. |
