-   General Tech (https://chevroletforum.com/forum/general-tech-10/)
-   -   water leak by goose neck (https://chevroletforum.com/forum/general-tech-10/water-leak-goose-neck-4778/)
billyboy Jan 13, 2007 8:52 PM
I have a 1999 Chevy Lumina with a V6 3.1 L.
I have replaced the Thermastat and Gasket to fix the leak. It is still leaking in the same area and I cannot seem to find the leak. I did put some stop leak in and still a leak. No water is getting in the oil.
The water leaks under no pressure.
Any sugestions PLEASE and Thank You.
313hitman Jan 13, 2007 9:10 PM
RE: water leak by goose neck
well this is a common problem with 3100's if your positive that you put your gasket in right then it might be a cracked housing. the housing material is weak and bound to break under little pressure. take it off and examine it. hope I helped...
