What type of flywheel to buy?
Hello,
I need to buy a flywheel for a first gen 350. I visited the Summit website, and I noticed that there are steel and aluminum flywheels, with various weights (15-40 lbs. on average), different diameters and two different tooth count (153 or 168). I have no idea which one to buy. Perhaps someone can give me recommendations if I provide engine specs and application. Motor: 350 cid .040 over forged crank and rods 10:1 comp. 750 dp Holley Wieand team-g intake iron heads, 2.02/1.60 1.6 rocker arms comp cam 288 dur. .488" lift Muncie M21 close ratio 4 speed Car: 1962 Stratochief (similar to a Bonneville) weighs around 3600 lbs. gearing is not determined, somewhere around 3.73:1 street tires, normal diameter This vehicle is primarily for street use. Does anyone have any suggestions? Thanks. |
RE: What type of flywheel to buy?
Get a 168 tooth ( Most Common ) 28-35 pound steel flywheel ( McLeod or any good aftermarket brand ) and a matching clutch, pressure plate and throwout bearing. Make sure to use a 350 - 400 Chevy starter and that should match the flywheel. Use a good aftermarket bellhousing to make the package complete and safe.
