Where does this connect to
https://cimg2.ibsrv.net/gimg/chevrol...131fa0d45.jpeg
Where does the right side plug go to, the other side is the tachometer and ignition to the distributor. Here's the problem I'm took out the computer assisted distributor and putting in a HEI distributor and I need the feed off of this wire above, for the ignition 12volts. I Took out the old distributor put in the new one and grabbed this wire to find It had pulled the right side plug out of whatever it was connected to and for the life of me I can't find where the right plug plugs into. It seems that it dropped behind the engine and I can't find it. Where should I be looking for the plug this goes to or if that can't be achieved where do I find a ignition wire that I can use in stead |
what are you working on
Originally Posted by Irish_alley
(Post 428435)
