HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
2011 HHR Won't Start
Old September 30th, 2019, 6:14 AM
country599's Avatar
Default 2011 HHR Won't Start
Hello Everyone,
I'm new here this is my 1st post please be patient...
I have a 2011 HHR LT 2.2 VVT engine 135,000 miles the timing chain tensioner locked up causing the head to break every single rocker arm. I pulled the head and found 2 bent valves so I ordered a replacement head installed it installed all new timing chain sprockets and tensioners gears and balancer chain and gears set @ 12:00 and 6:00 and 6:00as well as all guides etc everything. I set the timing Crank @ 12:00 VVT cams at 10 and 2 replaced camshaft sensors, crankshaft Solenoids. engine turns fine but will not start I have Fuel at the rail I have fire on all 4 plugs the head is the exact same head I took the numbers off the old head and ordered a rebuilt head with the exact same numbers stamped on it. I have check the timing 5 times to make sure I am correct. so now I am lost any help would be wonderful. Thanks
Old September 30th, 2019, 8:51 AM
Tokin1's Avatar
Well, welcome to the forum. Im new here too and its been pretty quiet. You might have bettter luck here https://www.chevyhhr.net/forums/ as there are many more hhr owners there. Pretty good group of people who are long time owners. Lots of good info.
Old September 30th, 2019, 10:21 AM
country599's Avatar
I signed up on the hhr net last week still haven't got accepted
Old September 30th, 2019, 6:37 PM
Tokin1's Avatar
Huh, I dont remember having to be accepted. I regiatered and started posting. Strange.
Jcdew67
HHR
April 5th, 2022 8:43 AM
aintchevy_itschitty
S10 & Blazer DIY and Useful Threads
June 2nd, 2017 7:54 AM
mirandaneon
June 20th, 2013 8:32 PM
Cain92
September 1st, 2012 10:53 PM
eishiba
April 15th, 2010 8:22 PM
Quick Reply: 2011 HHR Won't Start
