03 impala a/c
i have an 03 impala. the driver's side a/c vents put out warmer air by 15 degrees, while the passenger side works as normal at 55 degrees. recognized the problem as 'hvac side to side temp. difference'? would the problem be fixed by the climate control circuitboard or under the hood?
RE: 03 impala a/c
Could be the climate control unit, or a bad actuator that controls the temp on the drivers side
RE: 03 impala a/c
X2
RE: 03 impala a/c
what does "X2" mean?
RE: 03 impala a/c
means i agree with what he said
RE: 03 impala a/c
could you be more specific about what the bad actuator and the climate control unit are?
RE: 03 impala a/c
the whole unit that has the heating and air on it
RE: 03 impala a/c
The are 2 temp blend doors on the heater box, and actuators(or motors) that open and close them depending on what the HVAC control unit tells it to do. If the HVAC contorl unit is telling it false info, it won't work properly. Also won't work properly if the motor itself is bad
did you figure out your problem?
my 01 Impala is doing the exact same thing. |
Suggestions are above
| All times are GMT -5. The time now is 6:57 AM. |
