08 impala lt 3.5 engine knocking noise
I have replaced the cam and the crank shaft sensors in my car and I got rid of the p0011, and p0016 engine codes. but now a new problem has come up... their is a real bad knocking noise coming from the engine on acceleration. it sounds like its coming from the drivers side of the engine near the intake. it is a tapping noise. I am looking into the cam magnet now but idk if that is the problem because the magnet is on the passenger side of the engine and the noise is coming from the drivers side. but apparently the magnet is paired with the cam shaft sensor. does anyone know anything about this?
No, not really. But have you checked your oil level recently?
https://www.google.com/#q=2008+impal...noise&safe=off |
Originally Posted by sledge.impy
(Post 280224)
https://www.google.com/#q=2008+impal...noise&safe=off my car has that problem... but im talking about in the engine/trans. the clicking is coming from under the hood not in the dash. |
(Post 280224)
Originally Posted by firefighter831
(Post 280239)
I have been doing research and I see similar knocking problems and it seems that I might have a spun bearing so im gonna drop the oil pan and see if I find any metal shavings.
Or is it something that isn't random ? I've heard an LT1 350 with a spun bearing. It sounded like a random pebble/rock being tossed around. The pickup screen was half clogged with rubber gasket material that had made it's way into the engine oil pan while we did engine work. |
(Post 280241)
Does it sound like a random pebble being tossed around inside?
(Post 280242)
when I accelerate, and the rpms go up the clicking matches with rpms. the higher the rpms the faster the clicking. so ill save that for tomorrows project.
Well - check your oil level first. I had a 3.4L lumina that when low ticked quite a bit with the oil low. |
(Post 280244)
I'm going to guess not spun bearing.
I know this is from awhile ago but my impala is having the same problem, did you ever figure out what the problem was.
He had some posts where he pulled the oil pan off.. but nothing really ever since. :(
Maybe you bought his old car? |
