2000 Impala Power Steering issue
Have a friend of mine selling a 2000 Impala with Cruiser package with about 112k miles on it she said that the power steering is out. I know the pump is about 50bucks and not hard to replace but she said that the line that goes from the pump to the <insert where it goes here> is whats bad. Any thoughts on what would be a failure on the line? she was priced about $600 to fix it. Any thoughts?
if the line is bad it could be one of two things line is cracked and/or rusted or there are seals/o rings at the end of the line that could be bad might be a pain to get to you might have to take lots of stuff off to acess it
Originally Posted by suzuki-guy
(Post 95972)
i would say 500 dollars is a rip off!!! I shouldnt be that hard just get a haynes manual and it will tell you step by step how to do it!!
(Post 95976)
the gauge will probably prove to be more difficult depending on whats actually wrong
1 Attachment(s)
do you know where the power steering pump is located on the 3.8? it is a major PITA to get to it. just to fill the fluid is a challange.
this is a pic of the seriesIII supercharged 3800(L32), but its in the exact same place on the seriesII 3800 Attachment 14859 It's on the back side of the engine (closest to the firewall). Under the alternator, almost. If you look between where the heater hoses go into the engine, you'll see the cap. as far as the gas gauge goes its most likely the sending unit in the tank. my gas gauge doesnt work right when it gets below 1/4 tank. in order to get to it you dont need to drop the tank. i think GM actually did something that makes sence. pull the carpet up in the trunk. inbetween the spare tire well and the back seat there should be a plate with a couple screws in it. remove the plate and you should be able to access the sending unit and fuel pump from there. |
| All times are GMT -5. The time now is 8:23 AM. |
