2007 Impala washer problem
Have just joined and read a lot of info and questions posted here and am impressed
My 2007 Impala LT only had 20,000 km on it when I purchased it-now has 129,000 --the windshield washers won't work-washer fluid is full and not frozen--have been buying the Rain-X fluid-not the cheap stuff. I don't see a fuse listed in the owners manual---- the wipers work fine- does anyone have any ideas about problem |
can you hear the pump run when you're trying to spray? and do you notice fluid dripping anywhere after you try to spray?? more then likely the pump is bad or theres a leak in the lines
| All times are GMT -5. The time now is 3:10 AM. |
