ABS and trac control lights are on!
Im getting a code for a rear speed sensor but the bearing is still good and i dont like the abs so i was wondering if i could disable it somehow?
ABS Sensor Replacement | ABS Wheel Speed Sensor | ABS Brake Sensors | Anti-Lock Brake Sensor At 1A Auto
It would be best to just replace the sensor. |
Check the wiring in the harness from the connector behind the wheel hub backwards to the main harness as far as you can......often just a frayed or damaged wire, IMO.....not too tough a repair if that's what it is.....
| All times are GMT -5. The time now is 6:28 AM. |
