Awkward noise in engine bay
2015 Chevy impala
4dr 3.6 v6 Hi, I've noticed recently that there is a weird noise that sounds like it's coming from the engine bay, but im not positive on the location. It sounds like a rattling or almost a chain rubbing against something. When I hold on the brakes at a red light for example, it will make the noise. Also, I can hear it at times when the engine idles, but only below about 2k rpms. Any help on this matter would be greatly appreciated!!! |
Originally Posted by Cgreen
(Post 465101)
2015 Chevy impala
(Post 465108)
If you put it in neutral, does it still make the same noise?
(Post 465119)
It doesn't make the noise in neutral, so I'm also wondering if it has to do with the driveshaft
Chevrolet Impala 3.6 liter sedan: Problem: A driver may report that a growling noise is coming from the front of the vehicle. Cause: The condition may be caused by a loss of pre-load on the front-wheel bearings due to the axle nut. Correction: To diagnose the noise, re-torque the existing front axle shaft nut to 162 ft/lbs and test drive the vehicle. If the noise is eliminated, replace both front axle nuts with the updated part (P/N: 10257766). On vehicles equipped with the police package, add an additional Nord-Lock. I hope that helps you, Cgreen. I believe that you can rent a torque wrench at lots of auto part stores, so you won't need to buy one, just for a one-time use. I'd use Locktight on them, as well. |
(Post 465126)
I believe I found out the source of your issue, after quite a bit of searching, as it was quite intriguing to me. This is what I found out about your 2015
(Post 465132)
I will try this when I get out of work,, I greatly appreciate the help and will be sure to give you an update!
(Post 465133)
Please do so. I am very interested in the results, and I hope this solves your issue.
| All times are GMT -5. The time now is 4:00 AM. |
