ts13209 |
July 7th, 2009 7:47 PM |
Yes your vehicle has one and it is called a 'cabin air filter'. it's purpose is to filter the air that enters your vehicle, removing dust and pollen among other contaminants. On your vehicle I believe it is under the hood in an air box. Some manufacturers ( I know Purolator has in the past,) include instructions on changing the filter.
Edit: Also don't be surprised if when you do access your filter you see signs that rodents have tried to make a home there. On one vehicle I had , they constantly got into the filter and chewed t apart. This one was located behind an access panel in the glovebox. All the more reason to check and replace on a regular basis, Check your owners manual for the recommended replacement interval, if it isn't listed then one year or 12 to 15,000 miles is a good rule of thumb. Sooner if the vehicle is operated in dusty conditions.
