Engine troubles 350
Hi,
so I got this impala 65 with the caprice package about a month ago, shipped from Florida to Sweden. Turns out its a 350 csb in it. Anyway, Ive got a problem that I cant figure out myself. When I crank it, it starts right up, and dies about a second later. When I crank it and give it some gas, it starts up and revs and dies. The carbs a rebuilt Holley 4160, no vacuum-leaks as far as I can tell. Mallory distrubator. Whats the next step to check? Thx. |
Try squirting a little gas in the carb after it starts - if it keeps running that suggests a primary fuel problem - like filter, fuel pump, or carb needs adjustment (floats?)
I assume it has not run in the month you have owned it? BTW welcome to the forum - lots of good folks will help you here! |
(Post 427878)
I assume it has not run in the month you have owned it? BTW welcome to the forum - lots of good folks will help you here! Idk when it ran the last time, I bought it in december then its been sitting at the dock for almost two months. The owner said it ran well when I bought it. Thanks man! |
Turns out the ignition didnt work properly, the wire was kinda melted. Im going to replace it with a new one, the wiring diagram say its a resitance wire. Whats the purpose of it?
You probably have on your starter solenoid 3 terminals, large one is from the battery, other two are marked s, and r. S is from the switch, r is resistor circuit that goes to the elecetronic ignition. Back in the "olden days" with HEI the issue was burning out hei coils due to constant battery voltage to them. The resistor circuit is, and I'm not sure other than it breaks battery voltage down about 50%. When you initiate a start, full battery voltage is sent to the coil, key switch not in crank, run only the resistor side of the circuit is what powers the coil. I used to have a diagram of that, but you should be able to find it online.
FWIW, I suspect carb issue.If it was set for a period of time, you might need to re-kit it.
Originally Posted by kevinkpk
(Post 427970)
Whys the coil wired to the starter though? Couldnt I just buy the right resistor and wire it from the ignition key? |
Coil gets full battery voltage during crank. My recommendation, trace both ends of the wire, remove both ends, check with an ohmeter, if there is a resistor in the circuit, it will show.
https://cimg3.ibsrv.net/gimg/chevrol...a3e21f3f9.jpeg
This is how they wired it. Shouldnt the wire from the starter solenoid to the coil be placed on the starter positive? And shouldnt the ignition key get an additional wire to the coil? The car runs fine when the coils wired to the battery. |
i want to clear up my information, thought the "R" terminal was for the old points style ignition. thought it had something to do with the points needing 12v while cranking.
