2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Generator conversion
Old April 17th, 2019, 5:14 PM
Chris Turney's Avatar
Default Generator conversion
Looking to convert my 1962 Impala from a generator to alternator. Not sure what amp alternator to use?
Old April 17th, 2019, 7:52 PM
kevinkpk's Avatar
You need to post some specifics, is it a small block, radio, lights anything extra? If it's a 6cyl with nothing else electrical, and not an oversized battery, probably a 50 amp. You will also have to consider the alternator wiring will it require a voltage regulator?
Old April 17th, 2019, 10:04 PM
It’s a 283 small block looking to upgrade headlights to led
Old April 18th, 2019, 7:05 AM
kevinkpk's Avatar
LED's won't require as much power, and I recommended a 50 amp that's because I believe that's the smallest size. You can put whatever you want in the frame size that it will fit. As long as you're not powering up a city block size stereo.
Old April 18th, 2019, 7:53 AM
Get a 10SI alternator. They come in different amperage and are 1 wire easy hookup. I have done this many times and it works well and easy to do. You will either need to make or buy a mounting bracket.
