HELP! mechanic says head gasket blown on '03 Impala LS (video)
major problems: overheating/excessive pressure from radiator cap. steering wheel locked when i turned left. i replaced the battery and was able to drive it but the loud noise your hearing indicated i needed a tow to the mechanic, he replaced radiator and fan + alternator. told me i had a blown head gasket. i drove less than a few blocks away and the steering wheel locks up after i made a left turn. towed it home. So far ive replaced: radiator + fan alternator and i have: ignition coils module spark plug wire set upper intake manifold set water pump transmission master kit Now i need to find a reliable head gasket set, motor mounts, as the old ones are either worn or non existent ect. im replacing all the old worn parts so post your reccomendations below |
Sorry, not sure what you're asking for. But I'd make absolutely sure you do need a gasket and, if so, due to overheating, you may need a new head as well.
