Impala Light Bulb number/sizing guide
Impala Lighting Guide[/align]Scroll down for earlier models.[/align][/align][/align][/align]2006-2008 Chevy Impala
Low beam headlamp H11-55W High beam headlamp H9-65W Parking light 4157 Front turn signal 4157 Rear turn signal 3057 Tail light 3057 Stop light 3057 High mount stop light Assembly Fog/Driving light H11-55W License plate 194 Back up light 921 Front sidemarker 194 Rear sidemarker 194 Ash tray 194 Glove box 194 Map light 578 Dome light 578 Step/Courtesy light 194 Trunk/Cargo area 912 [/align][/align] |
RE: Impala Light Bulb number/sizing guide
2000-2005 Chevy Impala
Low beam headlamp 9006 High beam headlamp 9005 Parking light 3457ALL Front turn signal 3457ALL Rear turn signal 3057 Tail light 3057 Stop light 3057 High mount stop light Assembly Fog/Driving light 893 License plate 194 Back up light 921 Front sidemarker 194 Rear sidemarker 194 Ash tray 194 Glove box 194 Map light 194 Dome light 578 Step/Courtesy light 194 [/align]Trunk/Cargo area 912 [/align] |
1977 Chevy Impala[/align](May include 78-85 models as well, need confirmation)[/align][/align][/align]
Low beam headlamp H4656 High beam headlamp H4651 Parking light 1157A Front turn signal 1157A Rear turn signal 1157 Tail light 1157 [/align] Stop light 1157 License plate 194 Back up light 1156 Front sidemarker 194 Rear sidemarker 194 Glove box 1893 Dome light 1004 211-2 561 Step/Courtesy light 1003 1004 1445 211-2 Trunk/Cargo area 1003 Under hood light 1003 Instrument-general 168 [/align]194 Hi-beam indicator 194 Seat belt indicator 194 Brake warning 194 Directional signal indicator 168 Radio dial 1816 564[/align] |
I just wanted to add that the Sylvania bulb guide is great for any other make/model -
http://www.sylvania.com/ConsumerProd...lacementGuide/ I use it all the time when replacing bulbs for friends/family. |
Exactly where in the trunk is the light?
The size I want to know is the gauge BulbsI want to change the color on a 2009
2000 impala 22x9.5 rims help
I have a 2000 imapla the rims i wanna use are 22x9.5 tire is 265/30/22 i did a 1inch liftsotires fit with little room left might have to go up another inch but i also had to get a adapter but didnt know if i should get one with a 1.5 or 1.25 depth i ordered a set they were 5x115 to 5x5.5 1.5 space but they dont fit rims guy at tire shop said they would turns out i need a 5x115 to 5x5.5 but would they cause rim to stickout to much or is it ok seeing that rims are already 9.5 ( what it says inside rim wall 22x9.5)
I actually lookup and buy at headlights123 online. Just plug in the make, model & year and it gives you an organized list including OE replacement and upgrade. Makes a total pain in the neck job simple. If you do buy - they've shipped the same day to me every time.
If you are interested in changing the interior controls to LED, please contact me.
2014 Impala LT
Anyone have or know where I can obtain a list of all light bulbs on the 2014 Impala LT? I have the info from the owner's manual but want to know ones like dash, dome, underdash, etc.. Thanx......
