Low Tire Pressure message
Hey guys, wondering if anyone had some advice on this issue. I had low PSI and its now correct in all 4 tires, which is 30 psi according to the manual. I have an aftermarket radio, so I can't reset the message that way. I've tried the rediculous reset using the light switch and still nothing. I drive 30 miles to and from work every day which gives plenty of time to recalibrate. Any ideas?
Thanks, Paul |
RE: Low Tire Pressure message
are you making sure NOT to pull out the stalk all the way, rather to the middle setting (put car in on, pull from in to middle 3 times). Regards
Yeah, I tried that. After I made that first post, I went in the garage and tried pulling the fuse to the data link. That didn't work, so I disconnected the battery. That did work. So, if you can't get the message off and you have the correct PSI, just disconnect the battery.
what year is your impala
my impala is a 2005
