Need to clear low tire pressure dash light
The dash light came on for "low tire pressure". I checked the tires and yes, they were low. I put air in them and the dash light is still on. Is there a way to clear it? I looked through the forum and can't find the answer.
It might go away after several cold to warm start ups, but usually a dealer can clear the code.
I guess it's a different system than my Escalade. I can add air and watch the pressure monitor change, the dash light goes out as soon as it gets up to the rated pressure.
With the car running and radion off, hold the tune button in for about 10 seconds. The menu will come up on the radio. You scroll down a couple of options and press preset 1 i believe, then it should clear it. You might have to play with it a couple of times. It works.
