Need help from fellow 2004 impala (or other years) ower
My car's battery suddenly went discharged. While changing a new battery, I noticed that when the car is off, it still draws 1.72amp current. I did some work on the instrument cluster last week (changed a bad step motor) and may messed up sth. Could any fellow owners kindly measure the key-off current of your good running car for me? Thanks in advance.
I read on another forum, that the normal battery drain for a 2001 Impala with everything off and retained accessory power timed out is 90-100 mA. Hope this helps.
Thanks. I've finished pulling the left-hand fuses and removing of one bcm fuse cut the drain to 1.2amp. But it is still too high seems. More fuses to pull.
Originally Posted by Cap'n Dave
(Post 191631)
