p0102
so on my moms impala today a cel showed up and it was a code of p0102. i know its the mass air flow sensor low voltage. my question is... how can i fix this?
I did quite a bit of troubleshooting for the MAF code you posted. A couple of things you can do are take a look at all the wires and make sure they are in good shape. You can also invest in a can of CRC MAF cleaner and carefully spray down the wires in the MAF and see if that makes a difference.
i will start there. thanks.
| All times are GMT -5. The time now is 7:24 AM. |
