Relay/switch that shuts the radio off when you open the door
How can I tap into the power wire/fuse that shuts the radio off after you open the door?
I would like to have my police scanner, Garmin GPS, and XM radio shut off when I open the door just like the radio. TIA, Tim K. |
would help if you gave us the year
Yeah, that would help. Its a 2005.
im not sure about this..
but I think this is related to the computer... it gets a signal that door is opened.. and it shuts power off to those accesories. |
Originally Posted by rbarrios
(Post 87488)
It may be BCM controlled. in that case you will have to install a relay that will be activated on the open of the door switch.
In the driver kick panel, there is a harness that goes into the drivers door boot. cut it open and you'l find a yellow wire. It will test as R.A.P.(Retained Accessory Power)
This is the wire you are looking for |
Originally Posted by shawnvw
(Post 87498)
This is the wire you are looking for Tim K. |
Originally Posted by tskilbride
(Post 87508)
Thanks!!!
Tim K. |
Originally Posted by Charles Christen
(Post 461555)
just curious if the yellow wire in the door boot worked for you???
Tim |
